Carchimp - Nieuw Gamma
Kozakstraat 5 - B-8560 Wevelgem
Tel: +32 (0)56 40.25.33 - E-mail: info@dforce.be
http://www.dforce.be - Facebook
Dforce.be
Naam: Michaël
Auto: none
Bericht door Dforce.be »
Het Carchimp gamma wordt uitgebreid en de eerste producten vinden stilaan hun weg tot onze shop!
Deze week hebben we reeds enkele accessoires in ontvangst mogen nemen!
* Tire Dressing applicator - € 5.50
http://dforce.be/webshop/product.php?ca ... =39&id=395
* Detail Brush - € 6.50
http://dforce.be/webshop/product.php?ca ... =42&id=396
* Large Drying Towel - € 19
http://dforce.be/webshop/product.php?ca ... =35&id=397
* Yellow Clay Bar - € 17
http://dforce.be/webshop/product.php?ca ... =27&id=398
Dforce.be
Naam: Michaël
Auto: none
Re: Carchimp - Nieuw Gamma
En ook de producten vinden stilaan hun weg tot onze shop!
Carchimp Shampoo
Carchimp Shampoo is a ph-neutral and wax-safe cleaning solution,
our shampoo is super concentrated and only needs 5ml per 10l water!
Carchimp Snow Foam
Foam Fun! Carchimp Snow foam contains super foaming agents,
which makes it possible to stick to the surface for a long period of time
so it has the time to loosen dirt and grime for safer washing.
Carchimp Snow Foam is Ph-neutral and wax-safe.
Carchimp Clay Luber
Carchimp Clay Luber has been designed to minimize the risk of
marring and scratching during the claying process.
Clay Luber contains super gliding contents which makes it possible
to safely remove contaminations from the surface.
Carchimp Spray Wax
Carchimp Quick Wax is an easy to use carnauba based spray wax
leaving a warm and slick wet finishsuitable for all paint types and colors.
Carchimp Wheel Cleaner
Carchimp Wheel Cleaner is safe to use on all kind of wheel surfaces and finishes.
Strong formula to which will help to remove dirt and brake dust.
Binnenkort meer!
